14-02-2020, 08:09 PM
I have a series 2 xsi 16v can you change the diff with the gearbox insitu ?
Differential
18-02-2020, 07:55 PM
done it a few times on the GTI6 its tight and you have to remove 2 out of the 3 engine mounts
![]() https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
26-02-2020, 11:23 AM
Are you changing the diff for a LSD? Its a really nice upgrade on a 306 so i highly recommend it! The quaife ones dont require any maintenance either but only work when both wheels are on the ground. Youd need a plated diff for more gains but then it requires maintenance, so its not really for every day use.
