306 XND to D-turbo track car project
I put a post in the newbie area a few months ago explaining the project but unfortunately not much has happened to the 306 since then due to the purchase of a 106 1.5D for £100!!!!
Anyway the 106 went through its mot on the 21st so with that on the road for me to learn to drive in I can now concentrate on the 306 build and as I have a daily driver I can make the 306 into a track car or at least that's the plan  Rofl
This is as far as ive gotten so far with the 306.
https://www.dropbox.com/s/mau03zxsttdifv...1.jpg?dl=0
https://www.dropbox.com/s/rc6l2sm72ue2ip...2.jpg?dl=0
So this is how the car looked when I bought it in June 2018
https://www.dropbox.com/s/fwp0bn20hti75v...7.jpg?dl=0
This is what it looked like inside the day after i bought it
Couldn't help myself and took the front seats out and gave it a deep clean inside
https://www.dropbox.com/s/cnnn7fefznjirj...0.jpg?dl=0
That weekend me and a mate stripped the front end down to do a bit of welding  Dodgy
https://www.dropbox.com/s/p10z71nyze9sz9...1.jpg?dl=0
https://www.dropbox.com/s/z1zhdltljnevsq...2.jpg?dl=0
https://www.dropbox.com/s/60w0bw0pqtx1bc...7.jpg?dl=0
https://www.dropbox.com/s/x8f7bnr6r3zxcp...5.jpg?dl=0
Found a few spots that needed some work  Rofl
This was also some of my first welding hence why it wasn't that pretty Itwasntme
https://www.dropbox.com/s/lv7k2px7mzig88...9.jpg?dl=0
https://www.dropbox.com/s/64wb3xg68cl2t8...3.jpg?dl=0
Had to make my own brackets to hold the wiring harness in the wing on both sides
https://www.dropbox.com/s/ed4kfr0k68abou...9.jpg?dl=0
https://www.dropbox.com/s/ti6bhhc81ixfxj...2.JPG?dl=0
Bit of red oxide primer and under seal for rust prevention.
https://www.dropbox.com/s/34wdtwfrmbr67x....jpeg?dl=0
https://www.dropbox.com/s/zujncyq85irl20...7.PNG?dl=0
This the donor vehicle for the build (1999 306 D-turbo) that was bought a few years ago by a family member to used as a filed car
but hasn't been abused a grate deal but had the whole front tow hook pulled out and some body damage so wasn't worth repairing
Might have also had a little play with the pump and did a back box delete for fun Itwasntme
https://www.dropbox.com/s/6zfljxxb47rj5v...3.jpg?dl=0
https://www.dropbox.com/s/r1ip0cjc4h4357...8.jpg?dl=0
https://www.dropbox.com/s/3iylmg5ecmfmlj...2.jpg?dl=0
https://www.dropbox.com/s/yyoc4bvmohz5lc...7.jpg?dl=0
Stripped the car of its engine, gear box, front suspension, sub frame and rack, rear beam, wheels, front seats, few body panels
and some other bits before the shell went of to scarp   Sad
https://www.dropbox.com/s/a33jc3jhpip4tr...4.jpg?dl=0
https://www.dropbox.com/s/zbvs589yf54j6x...7.jpg?dl=0
Back to the XND 306
I got a phase 3 front bumper for it and some side skirts
Fitted the wheels that came off the donor that found there way on to the 106 a few weeks late
https://www.dropbox.com/s/5hn3ufct1qiyze...8.jpg?dl=0
https://www.dropbox.com/s/138jrlh9m7av64...3.jpg?dl=0
https://www.dropbox.com/s/rtkfk2kcy5qdpk...6.jpg?dl=0
https://www.dropbox.com/s/wsx0suvybqdthm...7.jpg?dl=0
Updated the rear end with the parts from the D-turbo and fitted the back box delete pipe for a laugh, didn't sound that bad for a nad
https://www.dropbox.com/s/5gz8nd27cu3iqs...9.jpg?dl=0
https://www.dropbox.com/s/j41bt9n4ji0rj0...0.jpg?dl=0
https://www.dropbox.com/s/n4l6bp6itv29e7...0.jpg?dl=0
https://www.dropbox.com/s/h9hex98jiqhnp4...4.jpg?dl=0
Head light masks got a quick paint
https://www.dropbox.com/s/h57rp92afgazw6...7.jpg?dl=0
https://www.dropbox.com/s/c8g4bpt7f12kae...0.jpg?dl=0
Front end is a little bent up so had a go at straightening it out before fitting the front end back together but will need some more work at some point to get the front to fit a bit better
So this how the 306 sits at the moment but with lots of rust repairs to do on the rear I cant see me having the new engine in it till summer
  DeeC’s 306 VNT Turbo Build / Show Car Project darrencurry0808 63 57,181 30-12-2020, 01:45 PM
Last Post: darrencurry0808
  Project Truck Turbo MkII, gathering dust ozonehostile 418 349,513 29-08-2019, 09:51 PM
Last Post: Dturboleeds
  Project- 306 2.0 8v Turbo PUGNUT_XS 243 220,621 13-12-2018, 08:32 PM
Last Post: Joep83
