Help finding seal/gasket numbers?
I’m struggling to find the large o ring that seats between the base of the fuel filter housing and the top of the thermostat housing.
Also the gasket number that seats between the back of the block and the plastic part that joins the 2 water pipes that run to the front of the engine.
Anyone point me in the right direction?
I think the O ring that goes between the filter housing and thermostat housing may well be part with the filter housing. Best bet maybe to try and just find somewhere that you can get pretty big O rings from.
The O ring for the back of the block to the water housing is part number 134028 but it says on servicebox no longer avalible but a quick search on ebay and i found this https://www.ebay.co.uk/itm/Genuine-Peuge...:rk:5:pf:1
Yes mate I presumed I could just get the o ring somewhere generic.
That’s the one for the back of the block yeah. Legend!! Cheers frosty, a little bit closer to getting it running again.
Ideal, if there are any other bits you need just give me a shout as i have a fair few spares about.
Will do, cheers for that.
  Part Numbers Pug0BZ3011 7 4,191 21-09-2016, 06:54 PM
Last Post: welshpug
  Finding Engine Number bigcheez2k3 10 6,062 28-08-2013, 11:58 PM
Last Post: Dum-Dum
  part numbers Daniel306 0 1,916 18-07-2012, 09:21 PM
Last Post: Daniel306
