Finding Engine Number
Insurance company are asking for my engine number, I guess so they can confirm it's a 1.9 XUD that's been swapped into it, but I'm having trouble locating it. I read this thread http://306oc.co.uk/forum/thread-10685.ht...+number%22
Which would tell me it's here I should be looking, but doesn't seem to be anything there on my engine.
[Image: khM5xpr.jpg]
[Image: x3ozQ2X.jpg]
it looks like its there faintly just very rusty try cleaning it up a bit
sand it down the numbers will apear as if by magic
Cheers. I'll give it a go, have already had a go at it with the wire brush to get it looking like that.
I had a similar issue with the DVLA for an engine change. But I was lucky to have a small metal tab just up from the starter, towards the diesel pump (in behind the injector lines) stating the number. Do you have one? Can't quite see from your pictures.
brake cleaner is good for cleaning stuff try some of that
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Got it cleaned up today, can pretty much see it although still a little faint.
What should an engine number look like? Would it be DHY followed by 7 numbers?
If anyone is really desperate to know I'm trained in the forensic recovery of engine/chassis numbers.
That's not the engine number, it's on a plate above that part. Silver piece in this photo just up from the yellow and black screw driver
[Image: Image512.jpg]
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
I don't think I have that, or I can't see it.
It should be on both, sometimes the plate is on the end of the belt cover. some don't have the plate
  Help finding seal/gasket numbers? doogle-d turbo 4 4,057 24-10-2018, 08:14 AM
Last Post: doogle-d turbo
  XUD9 Engine number location andy_diesel 3 5,685 18-11-2016, 07:44 PM
Last Post: bashbarnard
  Project engine number 3 Pompey306mark 21 11,947 23-11-2012, 06:35 PM
Last Post: Pompey306mark
