Ph1 Xsara VTS breaking
Guys,
I've bought a Ph1 98 R plate Xsara VTS which I'll be breaking. It should be being delivered over the weekend and I'll have more info then but it's a completely STD car. It starts, runs, drives, even has MOT until towards the end of September but the shell is knackered as the front suspension turrets are rotten apparently.
I'll say this now - the rack IS NOT available. Im keeping that. Everything else will be available. Ill put some prices, no idea if I'm close but will listen to offers as it all needs to go. Cars not even arrived and I'm getting earache....
Engine with 133k on it - £400
Gearbox - provisionally spoken for
Standard exhaust - provisionally spoken for
Rear beam £200
Front struts/springs £30
Brakes front £50
Brakes rear £25
Hubs £50 pair
Subframe £35
Wheels £50
Driveshafts £30
Not sure if there is anything else of interest/use on the shell. I'll start breaking early next week so will update then but get in touch if there is anything you are after.
Thanks
[Image: IMG_20180817_125311.jpg]
[Image: IMG_20180817_125236.jpg]
Engine, gearbox, brakes (front and rear), airbox, cat, wheels all sold.
Rest still available. I will have everything else I want from.the car stripped by the end of the bank holiday and then the car will be going for scrap.
Bits still to come off/left are:
Fuel tank
Fuel pump
Subframe
Hubs
Rear beam
Front struts
Engine loom
Servo
Get in touch if you want anything. Don't want much for the bits, shame to see any go to waste
Ok, pretty much done with breaking it now. Unless anyone tells me they are after bits from it, the shells going for scrap as soon as I can arrange it....
Bits that might be of use (and can post at cost if required):
Bosch servo - £15
Bosch front wiper motor - £10
Heater matrix hoses - £10
Front seatbelts - £15 pair
Upper steering column - £10
Fuel pump - £20
Engine wiring loom - £40
Drive shafts - sold
Front sub frame - £20
Front struts & springs - £20
Front hubs - Sold
Front wiper arms with what look to be relatively recent Bosch blades - Sold
Can't think of anything else.......if unsold it's getting slung in the boot when it goes for scrap!
Car now scrapped
  Xsara VTR breaking Ben_w 1 2,792 09-08-2019, 07:37 AM
Last Post: Ben_w
  Breaking - Ph2 Xsara VTS Ben_w 3 3,773 16-03-2019, 09:43 AM
Last Post: Ben_w
  Xsara VTS 2002 Breaking for spares miles 8 6,808 07-08-2017, 11:08 AM
Last Post: Nat30V6
