19-05-2018, 10:34 PM
Anyone know off hand the size in mm of the turbo outlet on a 2.0 HDi?
45mm comes to mind...?
Turbo outlet size
45mm comes to mind...? Wishes for more power...
21-05-2018, 05:45 AM
I thought it was smaller than that, 43 or maybe even 41mm. Try the intercooler guide threads, pretty sure at least one of those specifies.
21-05-2018, 02:12 PM
I've got the original black rubber connector in the shed, will measure the ID later if you still need it.
(21-05-2018, 05:45 AM)Poodle Wrote: I thought it was smaller than that, 43 or maybe even 41mm. Try the intercooler guide threads, pretty sure at least one of those specifies. Tried those,it just says to get the c5/406 bottom pipe.... Which I don't want to do... (21-05-2018, 02:12 PM)Uberderv Wrote: I've got the original black rubber connector in the shed, will measure the ID later if you still need it. That be amazing Wishes for more power...
Not been to the shed but this may help
Sorry lol looking at No3. Will go shed 42/43 mm3. Taken from a slightly squished section of hose (No1)
22-05-2018, 07:46 PM
Nice one... So you'd say 42mm would be a nice tight fit
22-05-2018, 10:11 PM
Yeah should be, a good clamp round it too. As we know access behind there is very limited.
23-05-2018, 06:02 AM
Well the joiner joins the bottom pipe to the compressor outlet, so if it says 41mm that means it fits both, ie the turbo too.
turbo outlet flange to make custom down pipe | pro_steve | 5 | 2,082 |
25-06-2015, 11:26 PM Last Post: HDi--Power |
Turbo Inlet Size on 1999 HDI? | JTaylor2005 | 4 | 1,342 |
01-12-2014, 12:42 PM Last Post: JTaylor2005 |
