Hard brake P-306
Exclamation
HELLO TO ALL .
i have problem with a brake to car 306 1998 1.9td.
First push pedal go to the floor and brake littel, in second push pedal go hard and hard. Vacum is working i was change tube and clean with petrol. What can be the problem : abd pump, master cylinder or booster. Waiting for answer
Sounds like air in system. Look for leaks or if something has been changed recently....it hasn't been blead properly.
(19-02-2018, 10:26 PM)Piggy Wrote: Sounds like air in system. Look for leaks or if something has been changed recently....it hasn't been blead properly.
The car was at brake servis and no air in the tube, haved to much in fron left tube but now i think dont have. Im confused what to change next - master cylinder or vacum or booster or abs pump.!! Ur sugestion
Does pedal go to the floor?
I have/had same issue turns out it was rear brake shoes and adjustment
(19-02-2018, 11:27 PM)pug_345 Wrote: I have/had same issue turns out it was rear brake shoes and adjustment
This will usually result in same 'nothingness' everytime you push the pedal.
If he is having to 'pump' the pedal to improve it, usually that's air in the system.
Sounds very much like air in the system. Has someone allowed the system to empty? There may be air in the abs pump, which will require you to find a loose gravel surface and make the ABS work to release the air, so that it can be bled out.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Dear i was change fron calipers.. so can u upload one photo to see what is that rear brake and adjustment i cant understen where exacly are they. Thnx a lot for answer
It's air. Blead the system properly!
It won't be rear adjustment if pumping it fixes it
Fixed mine no problem since had to pump mine but might be differnt for another that was just my problem
(20-02-2018, 01:50 PM)Piggy Wrote: It's air. Blead the system properly!
Today i changed Abs pump - the pedal in first time no brake good when pres second time brake ok ??? Do need to change master cylinder ( pump ). Thnx to all
Needs bleading properly!!!!!!
Heart
This all from 406 i wont to put in 306 can be that possibel!?
1. Booster
2master cylinder
3 calipers
4. Disc front and rear
No.
only the master can be made to fit, nothing else is worth the hassle.
have you bled the brakes properly yet?
(26-02-2018, 05:00 PM)Piggy Wrote: have you bled the brakes properly yet?
Waiting my brother to done with paint somecar and to empty the garage and i will start change some parts. Thnx for your question u will be informed about my problem.
  Hard Brake Pedal ct-hdi 5 3,506 04-01-2016, 06:57 PM
Last Post: ct-hdi
  Hard brake pedal? clarkey2010 1 2,177 09-04-2014, 08:09 PM
Last Post: Piggy
  Brake to hard jonas306 8 5,565 14-02-2014, 10:10 AM
Last Post: jonas306
