Brake to hard
Hi guys, recently a bought a 306, i did had the time to test it properly, i brought the car today to work, and i notice that when had to brake in a shorter distance the pedal was hard, and not braking with efficiency! Is it the abs pump or brake pads?the rear ones were replaced by the former owner a couple of weeks ago..
Regards
Check that pads are all ok, that is a good first check.
If the pedal is going hard that can indicate a lack/loss of vacuum going to the brake servo. Check all your vacuum lines are attached and intact Smile
Id be starting with the vacuume pump , lines etc and working back to the servo
(14-02-2014, 09:22 AM)swampy Wrote: Id be starting with the vacuume pump , lines etc and working back to the servo
That's assuming its an UX10 engine with a pump...
Yeah need to know what engine... The hdi and xuds used pumps, the petrols used the natural vacuum from inlet
I have a Hdi DTurbo from 99 Ph2...If i connect in a diagnostic machine will find the fault?
It might point the in the right direction but i doubt it.
(14-02-2014, 09:42 AM)jonas306 Wrote: I have a Hdi DTurbo from 99 Ph2...If i connect in a diagnostic machine will find the fault?
In short, no.
If the brake pedal is very hard to push, but doesnt go down the floor and the harder you push the more the car slows, then it all points to a failure in the brake assist system...or servo.
Either the servo has a leak, or the vacuum pump and pipes which create the vacuum within the servo have failed or are leaking.
If i have time i will put in the ramp at work...I talked with my mechanic he referred the servo also..Thanks for the help, i will give news soon..
Exclamation Hard brake P-306 Fannpann 15 9,136 28-02-2018, 10:28 AM
Last Post: Fannpann
  Hard Brake Pedal ct-hdi 5 3,638 04-01-2016, 06:57 PM
Last Post: ct-hdi
  Hard brake pedal? clarkey2010 1 2,218 09-04-2014, 08:09 PM
Last Post: Piggy
