Painting fuel rail
I have new injectors to fit on my 6 but was thinking of painting the fuel rail at the same time.
Any top tips? I assume remove pressure regulator and injectors. Block any holes, key then spray?
Yeh I dont think its anything special. if you can get any fuel resistant paint I guess thats a bonus. They normally look pretty terrible so id make sure you get any rust off properly and possibly some rust treatment.
Thank you got some kurust and will give it a good sand down. When fitting the new injectors will it be okay to use Vaseline to lube the injectors? Would make sense to me but seems not everyone agrees online... I have silicone grease i could use instead...?
The place I got my injectors reconditioned said just to use a little clean engine oil. I guess the o-rings are nitrile rubber n oil won't affect them.
  6 inlet painting ayton autosport 18 10,055 27-08-2014, 09:55 PM
Last Post: impotentials
  Metal vs Plastic fuel rail? Dum-Dum 11 6,749 19-10-2012, 08:05 PM
Last Post: Dum-Dum
