Semi ecu bosch throttle position sensor
Wanted: Semi ecu bosch throttle position sensor
As above in need of the throttle position sensor and everything that connects it to the throttle arm and bracket that holds it in place basically everything to fit it to mechanical my pump.
Will need to be posted.
Thanks in advance
I have one.
But fyi, if your throttle arm shaft is a short one...you may struggle to bolt it to the throttle shaft
(06-08-2017, 12:41 PM)Piggy Wrote: I have one.
Price posted? Assuming you have everything with it to attach it to the pump?
I have a whole semi ecu pump to break for spares
(06-08-2017, 05:18 PM)Paul_13 Wrote: I have a whole semi ecu pump to break for spares
How much for the bits I'm after also the gov cradle/throttle shaft just incase I need that.
Rather sell it whole, don't want a lot for it
  FOR SALE: Comma semi-synth SX75W-90 GL5 oil, 5litres toseland 0 1,375 22-04-2016, 09:47 AM
Last Post: toseland
  Wanted: bosch pump throttle arm strut Jonny81191 6 3,887 02-04-2015, 07:40 PM
Last Post: Jonny81191
  Wanted: semi eci bosch TPS Piggy 2 2,094 12-06-2014, 03:23 PM
Last Post: Piggy
