Threads: 49
2
Car Model/Spec: 306 HDI Estate + 205 HDI
I've been using Linux on my laptop for a few years but now I'm back in a HDI I need to re install windows for stuff like PP2000 and WinOls etc....
So my problem is the key on the sticker has rubbed off as some genius decided to stick it to the bottom of the laptop. Anyway im trying to make a bootable usb with windows 7 ultimate but can't download it from Microsoft because they want the key. Has anyone ever bought a key off ebay? If so was it ok?
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 41 thank(s) in 38 post(s)
if it's not, then just apply for e refund from ebay sellers guarantee if its covered, if not paypal will likely sort it
/Toseland
Threads: 136
11
Car Model/Spec: 306 hdi stage 2 & 205 DTI
Given 39 thank(s) in 39 post(s)
An alternative would be to use a virtual box and run xp that way. I've just done the same to get INPA working on XP using Windows 8
Threads: 52
4
Car Model/Spec: XSi 16v
Given 83 thank(s) in 81 post(s)
Without the original product key you might struggle. There probably are hacks available but I believe the keys on Windows 7 and later are tied to the MAC codes of individual devices. If someone gives you a key already registered to another computer Microsoft is likely to recognise it isn't valid and not accept it. (For example, people who change the motherboard in their computer find W7 doesn't work after because it thinks you're trying to install it on a different computer). It'll only work if you're given a key that has never been registered to another device. Some online retailers claim to supply spare installation discs & keys that were never bundled up with computers.
You may be able to get the original key from the manufacturer of your laptop. Also, if you phone MS support & explain you needed to re-install W7 but the key has rubbed off the sticker they are apparently quite good at giving you a new key (possibly after a bit of a grilling) if they conclude you're plight is genuine.
Threads: 371
29
Car Model/Spec: ford fiesta
Given 82 thank(s) in 82 post(s)
You have a pm
Threads: 541
124
There is a thing online that will generate a random product key.
Threads: 82
27
Car Model/Spec: E92 335i, GTi6, HDi S2
Given 22 thank(s) in 22 post(s)
Look for a program called KMS, just be very careful where you get it from as there are a lot of fakes.
