Favour for a friend - Juddering/shaking under braking
Evening all, quick question for you.
My friend asked me to diagnose a problem with her car, it judders and shakes under braking. Only really happens under light braking/low speeds, tracking and wheel balancing are fine, any ideas? I thought maybe a warped brake disk, other than that I could only think maybe a fcuked bush somewhere but how's best to check?
Cheers guys.
[Image: sigcopy-1.jpg]
One of them favours eh? Lol
If its a bush, check for play around the wishbones, TRE as is could be steering rack if thupland play, or like you say could be a warped disc. Rotate it and see if It hits the pads at any point.
Just a pointer, my caliper is f*cked at the moment, and is loose to the points can wobble it with one finger. That causes juddering under breaking....
And yes I need to address that, I know...
Bad discs and pads....probably front as the rears do sod all!
Rears are drums anyway, so shan't be that. Is the play the usual grab the wheel at 12 and 6 and give it a shake?
Kezzieboy Wrote:Rears are drums anyway, so shan't be that. Is the play the usual grab the wheel at 12 and 6 and give it a shake?
Yeah. Also do it at 3 and 9.
And 13.37 and 16.45 Wink
Just out of curiosity, what car is it?
Mk4 fiesta, so many rust repairs it's hilarious, I was petrified to even jack the thing up lol
Typical fiesta... :grin:
[Image: Sig3_zpscd005eb1.jpg]
It's most likely a warped disc tbh. Turn the wheel jacked up and you'll probably hear the disc scuffing the pad if its out of shape.
Could also try hard breaking when not holding the steering wheel, see if it moves or pulls to one side etc..
  Braking on and off MY95 20 8,123 19-03-2015, 10:20 PM
Last Post: MY95
  what braking system Willo 3 2,832 23-02-2013, 01:21 PM
Last Post: Willo
  juddering under braking 318d4n 8 4,373 04-08-2012, 05:04 PM
Last Post: THE_Liam
