Changing ECU to bypass immobiliser?
Hi.
I've wrote about this several times and nobody can give me a good answer.. It seems like these cars were pretty faulty with their immobilisers and nobody really knows how to fix it?
Info:
Car: Peugeot 306 XS -97
Engine: 1.6 Petrol
Gearbox: Manual 5 speed
Immobiliser: Keypad
ECU: not sure
So the battery got drained and the car refused to start after that. Even if I entered the correct code. The red and green light is both lightning up after I entered the code and the engine will just spin.
My question: The only solid answer I've read on several forums is changing the ECU to a ECU from a 306 without an immobiliser. Is this possible? If so, what ECU will fit? Any ECU from any 1.6 petrol XS -97 or is there some rules that certain ECU's won't fit or something like that?
If there is anything you wanna know, just ask! Smile
I can update that I've found 2 used "ECU"s, but I'm not really sure they are what I'm talking about.
[Image: peugeot_306_1997_insprut_bensin_styrenhet.jpg]
Are these what I need in that case that an ECU swap is on the table?
The site that these are on is calling the "Fuel injection ECU". Also from a 306 XS 1.6 "NFZ" Manual -97
  central locking bypass auto unlocking andyw 1 3,731 04-07-2021, 03:58 PM
Last Post: Mighty306
Thumbs Down Immobiliser thebluepearl 11 6,041 20-05-2016, 12:05 PM
Last Post: insomaniac45
  Xantia 1.8 16v key/immobiliser Piggy 7 5,539 26-02-2016, 04:02 PM
Last Post: Toms306
