Universal fan wiring
Anyone got a diagram or something that could help me get my universal fans wired into the relay, got no other way of testing them, unless running the car up to temp ..... bit of a ball ache
Surely you can turn them on high speed manually using the A/C button trick? Just need to bridge pins (think it's 1 and 3?). Can't help you with the wiring aspect though I'm afraid
1 and 3 is high speed yeah midnight, just bridge pins 1 and 3 on the compressor pressure switch thingy (brown 4pin plug) and you're away..
put the AC switch on and the fans will automatically come on
with mine i simply cut the wires off at the fans themselves, and wired them into the ends of the standard relays.. sorted!
/Toseland
Spot on , il give it a go tomorrow when I've got abit more light , il post up on how it comes on haha , thanks again guys [emoji1360]
bridge the relays like in these pics and the fans will run either half speed or full speed off the permanent feed instead of needing to turn the ignition on this is how i test mine.
[Image: 1bdd0b54de066589740bc029ade4ad2f.jpg]
[Image: 8a5bc448ab09b2fe3637254510ba26d8.jpg]
I got a rad temp switch off a 205 (comes on at 93 degrees I think) and made my own simple wiring loom with a relay. Don't have to worry about remembering to turn the fans on then. The stock wiring for the rad fans is over complicated imho
  Universal Cruise Control Kit Daniel306 11 8,381 30-12-2014, 10:42 AM
Last Post: Daniel306
  Universal sports cats lolsteve 2 2,877 06-02-2014, 05:22 PM
Last Post: lolsteve
  Branded or Universal Back Box? MRiches 10 5,854 24-07-2013, 09:22 PM
Last Post: Midnightclub
