Universal sports cats
So recently purchased a new janspeed manifold + decat pipe for £100, bargain since the manifold alone is ~£250 new.
Problem is the decat, while it'll obviously fail an mot it apparently looses power on the vvc engines which has been backed up by dyno results
The plan is to weld in a universal sports cat like that found on ebay
http://www.ebay.co.uk/itm/161104947289?s...1423.l2649
Does anyone know much about them or used them though? Before I buy one and find out it's no better than the standard cat
[Image: mcetg0.png]
Why do they Loose power due to not enough back pressure?
Team Doesn't own a 306
Edit: Just to shorten it down a bit
http://forums.mg-rover.org/showthread.ph...ost1885537
"With respect to the F/TF, then the space available limits primary and secondary pipe length to being less than ideal; tertiary pipe length availability is even worse (especially on non 'purpose fabricated' systems). This causes a limitation in how efficient are the after-market systems (in terms of tuning). The VVC engines will suffer most in this respect because they have a hotter inlet cam timing than do the MPi's. What seems to be happening with the power loss on de-catted VVC motors is that the tertiary pipe length is far too short (hence the drop in power), whereas, on their catted (or sports catted) cousins, the actual distance the gas flow (and therefore the standing wave) 'sees' is longer (because of the nature of the flow through the cat), hence catted VVC motors do better than de-catted ones."
The non vvc apparently do better without a cat, it's just the 200 shell that does better with one
[Image: mcetg0.png]
  Universal fan wiring Dezone666 5 3,637 10-02-2017, 08:54 PM
Last Post: Sambarker
  Universal Cruise Control Kit Daniel306 11 8,620 30-12-2014, 10:42 AM
Last Post: Daniel306
  Cats! lady gardens or Awesome? Dum-Dum 57 32,482 08-08-2014, 12:17 PM
Last Post: JamesPT
