Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Noticed recently the Gti is starting to wiggle.
It feels like there's a bit more play in the steering before getting any result and when going over bumps/hard corners it feels like the backend is coming around
It's not just me being over enthusiastic or slippery roads as its getting worse and doing it in places it never been an issue before.
I've not had a proper chance to look at it yet but wanted some advice about where to start.
And no, unfortunately haven't done a RWD conversion
Threads: 117
119
As above, sounds like classic beam mount symptoms.
Threads: 164
25
Best way to test and best replacements then boys?
Threads: 164
25
I don't think it has ... Will have to double check now lol
Threads: 465
114
Car Model/Spec: Vauxhall
Given 98 thank(s) in 92 post(s)
if it has solid mounts id go for shit rear tyres on a damp road or an imbalance of the brakes or even using the brakes into the corner
Threads: 42
28
Given 89 thank(s) in 88 post(s)
check the rear dampers are ok, and that the beam isn't worn out.
Threads: 164
25
I'd hope it's not the beam was a Steffens rebuild within the last 2 years
Sent from my iPad using Tapatalk
Threads: 58
5
Car Model/Spec: 205 gti6 supercharged
Given 16 thank(s) in 16 post(s)
As said check your mounts especially the fronts they get over looked. Im not sure if chris fitted new when i built it for him.
Threads: 164
25
Ill pop it in the air this week/weekend and see where we're at [emoji1303]
Threads: 164
25
Had a nose under last weekend, definitely solid mounts and I've got yet another goosed rear shock, that's now 2 on the same side in 7 months
Threads: 164
25
They're Koni adjustables
Threads: 102
18
Car Model/Spec: Ph.1 Gti-6 63k
Given 22 thank(s) in 22 post(s)
Koni yellows? Mine have been great and still look and feel as new, including after having been on sprints, prescott etc.
Strange!
62k Diablo Phase 1 Gti-6: Project Thread
Threads: 164
25
10-02-2017, 09:47 PM
(This post was last modified: 10-02-2017, 09:48 PM by rocker8742.)
Is a bit weird, although don't know what previous life they've had.
need to see how much Koni charge for a refurb and maybe set them a little stiffer
Out of interest how hard are yours set?
