Wireless dongle; talk to me.
Short story - internet is being installed.
My desktop PC has no wireless adapter nor does the office have an internet point and I'm not keen on running cables across the house.
Anyone point me in the direction of a decent wireless dongle?
Any advice would be great
Ive used theses before, pretty good doesn't effect the speed much.
http://www.argos.co.uk/product/5742734?s...id=GS001&_$ja=tsid:59158%7Ccid:598893978%7Cagid:24310582250%7Ctid:aud-144400486596:pla-215576371490%7Ccrid:86867309210%7Cnw:g%7Crnd:7571484655295671572%7Cdvc:m%7Cadp:1o2&gclid=CjwKEAiA2OzDBRCdqIyIqYaaqQoSJABeJZdiDA1V57AWEC0WG9ogZq2-RlVaVT_-F1ui0TDngL6RBRoCwrXw_wcB
Something like this would be decent, TP Link is a half decent brand and buying from amazon allows you to return it aswell just in case it sucks although it shouldn't bought cheaper iones in the past and they're still going.
https://www.amazon.co.uk/TP-LINK-TL-WN82...0088TKTY2/
1999 - Black Rallye A/C
2002 - Silver 206 1.4 HDi LX
(15-01-2017, 02:37 PM)306carter Wrote: Ive used theses before, pretty good doesn't effect the speed much.
Ah, that looks spot on.
I've seen the USB dongles but expect they'd be somewhat slower than the cable
this is the exact thing i use. fricken brilliant. i can have a cable plugged into the router and its got the same download/upload speed as upsatirs using these.
http://www.maplin.co.uk/p/tp-link-av200-...-kit-n11nf
this way you can be plugged in all the time
why dont you just use your phone as a wireless hotspot? the data is going to cost you pretty much the same amount if youre on a sensible contract.
(15-01-2017, 07:04 PM)Eeyore Wrote: why dont you just use your phone as a wireless hotspot? the data is going to cost you pretty much the same amount if youre on a sensible contract.
I think he means a usb wifi dongle, not a usb 3G dongle.
Something like this would get good signal for a USB dongle, but as others have said powerline adaptors might be better.
If you have a reasonable router (most routers are OK now for signal) then the limiting factor will be the antenna on the card itself.
if you have a PC then a normal wireless card (PCIe or PCI) with an uprated 9dBi antenna such as these 2
~Card
https://www.amazon.co.uk/PCE-N10-Wireles...1484569785
~Antenna
https://www.amazon.co.uk/Booster-OMNI-Di...words=9dbi
we had an issue with my house (being an old house) where one of hte compters was sucking ALL of the bandwidth from the modem trying to connect repeatedly due to a very poor signal (half of one bar).. fitted this and moved it away from the back and it went form 1/2 bars to 5 bars and fastest connection available..
Obviously you will need to purchase more if you have a wireless card with more than one antenna fitted as standard
if you want USB then https://www.amazon.co.uk/YUNDA-Wireless-...eless+card and one of the above antennae
/Toseland
oh i see. my bad. You may be able to plug in a phone (connected to your wifi) and get internet through the micro usb cable.
I've been using the TP link AC1200 USB adaptors on everything for the past couple of years, keep up with 300 meg internet just fine, signal levels are good even over long distances.
You could try these. Plug one in to a socket near your router and the other in your office. Then plug a network cable from the plug to your pc job done.
Check this out at Amazon.co.uk
TP-LINK TL-PA4010KIT V1.20 AV600 600 Mbps Nano Powerline https://www.amazon.co.uk/dp/B01BECPIMC/r...Fyb37FWQV1
Hope it helps
Sent from my GT-I9505 using Tapatalk
just a decent wireless dongle, and a fat antenna and its done.. half the price
/Toseland
Thanks all for feedback; will have a proper look through the links later!
I've got 1200mbps powerline adapters in 4 locations in my house. And an Asus router which is all singing and dancing as well as a Netgear range extender.
But a cheap starting point for you could be
Look at this on eBay http://www.ebay.co.uk/itm/161265471118
  Help with ADSL wireless router DeeTurbo 6 2,237 31-05-2018, 11:27 AM
Last Post: Magenta Sunset
  Tool Box Talk cully 22 5,601 26-07-2016, 09:44 AM
Last Post: Frosty
  Colleagues stolen laptop, IP trace (talk talk isp) stevieg 11 2,689 05-12-2015, 12:22 AM
Last Post: stevieg
