Threads: 465
114
Car Model/Spec: Vauxhall
Im so glad i raised my concern as I have just been out and measured some voltages
from Chassis to Neutral i could measure 110volts
from chassis to live i could measure 110volts
hmm that would give you a nasty tickle
so I have now installed a link on the Inverter supply neutral to earth/chassis
this has given me an earth path via the van chassis
taking the same measurements again they were
from Chassis to Neutral i could measure 0volts
from chassis to live i could measure 220volts
I am a lot happier now the van will be a lot more safe running the inverter
and as an added bonus
the socket tester is ticking all the correct box's
before it was showing NO Earth!
Threads: 465
114
the final part of the electrical jigsaw turned up today, the 12v control panel,
which is now all wired in and working
only thing left electrical now is to wire in the Tap and pump for the water
until i want to change or add stuff!
and the rats nest behind the panel
Threads: 29
Given 7 thank(s) in 7 post(s)
When's the remap then?!
Makes sense you're a sparky now, getting your head around all that.
Threads: 465
114
Threads: 3
Given 4 thank(s) in 4 post(s)
coming along nicely this cully
Threads: 19
Threads: 465
114
time for cupboard doors
had to do some thinking on the two large lower doors as i wouldnt be able to swing them open with the bed in the way
so i made them into lift off panels the very top one hinge's upwards
no handles yet!
Threads: 3
Top job , really coming together
Threads: 101
Car Model/Spec: 306HDi 90 LX
what will be your plans for water & waste tanks?
It goes, it stops (as reqd).
Hate Housework!
Threads: 465
114
09-04-2017, 06:44 PM
(This post was last modified: 09-04-2017, 06:49 PM by cully.)
(09-04-2017, 06:21 PM)Magenta Sunset Wrote: what will be your plans for water & waste tanks?
done
plumbing done
still need to cut the dropout vent through the floor
think i will be getting some smaller water containers too,
and not where i would like the bottle but no choice really
Threads: 465
114
11-04-2017, 07:02 PM
(This post was last modified: 11-04-2017, 07:02 PM by cully.)
Flatpack Rock n roll bed can you see it I can't yet?
I want a 6ft by 46" bed is to fit within a 800mmx800mmx 46" area
wish me luck
Threads: 371
29
Car Model/Spec: ford fiesta
fricken hell i dont look at this thread for a while and boom its had loads done!! you dont hang around sir
Threads: 465
114
12-04-2017, 07:56 PM
(This post was last modified: 12-04-2017, 07:58 PM by cully.)
pondering beds, seats, fold out shit today i came up with a plan!
remember the breif from the last post!
"I want a 6ft by 46" bed is to fit within a 800mmx800mmx 46" area"
so am going to attempt to make it
if it works or even fits will be a miracle!
but here go's for shits and giggles!
dont rely on the measurments if you use this idea as it was flexible ish
so i started cutting and welding
checked the basic 6ft x 46" frame would fit
then started adding the fold points
End of play today i have got a welded 6ft bed frame that needs hinges and cutting also requires altering to fit wheel arch profile when folded
on thing i have suddenly realised a SWB Vivaro with a 6ft bed dont leave a lot of room!
Threads: 47
14
Given 20 thank(s) in 20 post(s)
Double mattress slung in the back of a van FTW.
But seriously, as Phil said.
Good work man, it's coming on very well.
I Don't Have A 306.
Threads: 62
Car Model/Spec: Megane 265 + SHB Gti 6
Given 6 thank(s) in 6 post(s)
Swivel seat's on the plan cully?
Threads: 465
114
(13-04-2017, 10:28 AM)Lwilliams Wrote: Swivel seat's on the plan cully?
yes it will give more room
Hmmm well that failed!
time to look at something else
the majority of the steal is folded into the wheel arch, may of worked if it was narrower
currently sat looking at Futons
Threads: 62
10
It might fit if you de-cat it?
HDi Owner for 200k/9 years
Threads: 465
114
Bed MKI cut up to make Bed MKII
I am happier with this one as i can open cupboards and have more storage under the bed
Threads: 465
114
folded up bed frame
unfolded bed frame
lift up rear section to create bulkhead for transporting larger items
Threads: 465
114
half of infill done on the bed before work
nice use of scrap roll cages for the wire infill
Threads: 465
114
Threads: 465
114
just back from a week driving around Wales, found the Van to be well under-powered on the welsh hills so got it on some diagnostic machine to find i have a dead MAF sensor,
£100 Later the van is a different animal drives so much better
symptoms were lack of power bellow 2500rpm always changing gear to chase the rev's where the power was
No fault codes logged only visible on live data on a drive MAF values not changing
anyway great week away lovely weather
we cheated a little as we booked a Sun holiday short break so stayed in a static home
off away again this weekend East Sussex should be fun
Threads: 127
33
Car Model/Spec: ZX Volcane TD
This is epic, great work cully
Threads: 465
114
23-05-2017, 04:30 PM
(This post was last modified: 23-05-2017, 04:37 PM by cully.)
have been looking for something to turn my faded grey/black plastics back to black
after much searching I think i have found something better than peanut butter and cheaper than any car stuff in a tin
just mask up and paint on, took around 3 coats to go from grey to black the finish is excellent no brush lines or shading not sticky nor does it rub off
at 39p a bottle cheap as chips too
what do you think?
and what do you think it is Im using
Threads: 162
21
23-05-2017, 06:02 PM
(This post was last modified: 23-05-2017, 06:03 PM by DeeTurbo.)
Wow, 39p and it looks great.
I haven't clue what it could be.
How did you hear about it?
Threads: 8
Car Model/Spec: 405 SRDT
Well, my guess with the chips reference and cost it would be vinegar.
Threads: 465
114
found it by trawlin the net like most things
emptyed the bottle into a pot then used a paintbrush to apply it
Threads: 52
Car Model/Spec: XSi 16v
Given 83 thank(s) in 81 post(s)
Genius! Will be good to know how it lasts as lots of black plastic on my phase 2's is looking fairly shabby.
Threads: 465
114
Threads: 465
114
