29-11-2016, 03:44 PM
I have a 306 his and had air con pump removed and pulley so fitted a 6pk 1165 I think it was and they keep burning out and snapping help sick need car for work ..
Aux belt problems
29-11-2016, 05:34 PM
What crank pulley are you running?
Sounds as if the belt your using is too short, using a 1185 on mine with no issues.
29-11-2016, 09:32 PM
(29-11-2016, 05:34 PM)MY95 Wrote: What crank pulley are you running? I have just put one on tonight there and been driven and is red hot and smoking dingo if it's off olds belt where it melted on pulls but dose not have aircon pump or ideler pulley
Either too short, or something has seized up.
Id go for something seized, tensioner or guide Sent from my LG-H850 using Tapatalk
29-11-2016, 11:29 PM
As above, check all your pulleys by hand. I would use the idler pulley with a 1185 as it gives a bit more wrap around the alternator.
30-11-2016, 06:12 PM
Cheers lad put a 1185 on and seems spot on for now ?
Belt problems | iigodiix | 4 | 2,724 |
17-02-2014, 07:01 PM Last Post: iigodiix |
