Wanted: Parts for the gti6
Theres a few bits im after for the gti6, i will prob be adding to the list when i find out more bits i need. If you do have any parts i'm after or come across any on facebook etc let me know. If a bit of a distance away ideally parts will need to be delivered but happy to usually pick up parts if localish.
Battery live and earth cables - sorted
Throttle cable
Gti6 sump - sorted
Gti6 cat (ideally after a genuine 1 but i know not many of them about) - got an aftermarket 1 but ideally still on the lookout for a genuine sorted
Phase 3 spoiler sorted
Standard CD stereo
Standard steering wheel - sorted
Rear arch liners sorted
Bottom rad hose (push in with metal clip style) sorted
Gti6 gear knob - sorted
Gti6 standard airbox and pipe work - sorted
Gti6 decat (proper 1 if poss instead if a homemade jobbie)
Body panels in astor grey and pretty good condition
Bonnet
Driver side wing
Side skirts
Front bumper
(07-11-2016, 07:32 AM)Frosty Wrote: Battery live and earth cables
Gti6 sump
Bottom rad hose
i have these
rad hose there are two types
plastic push fit with plastic wing clips or metal with metal wire retaining clip?
GTI6 Info
i would attempt to make up your own battery cables as i doubt any original ones will be decent. Maybe peugeot still do them?
Ive got a 6 sump but its got the ac mounts missing.
good luck finding astor parts! or any for that matter.
Gti6 sump
Bottom rad hose
i have these
Ok ideal ill message you later on cully.
The bottom hose is the newer type with the metal wire retaining clip.
(07-11-2016, 01:08 PM)Eeyore Wrote: i would attempt to make up your own battery cables as i doubt any original ones will be decent. Maybe peugeot still do them?
Ok i'll see how I get on. Ah ideally I think im going to be after a sump with the mounts as I want to try and get the air con working.
Yeah astor panels will not be easy to get hold of but I thought if I asked the question on the off chance someone may have or know of some.
Got the hdi steering wheel here mate, maybe battery cables too, can't remember what I took off
(07-11-2016, 05:57 PM)rocker8742 Wrote: Got the hdi steering wheel here mate, maybe battery cables too, can't remember what I took off
Ok mate, ill drop you a text.
Frosty if you would take non astor panels i could supply them for £30 collected Smile Might also be able to do a deal on other parts.
Team Cyril
(08-11-2016, 01:10 PM)Matt-Rallye Wrote: Frosty if you would take non astor panels i could supply them for £30 collected Smile Might also be able to do a deal on other parts.
Ok matt ill bear that in mind cheers. You got any of the bits on the list that aren't body panels?
Updated the first post with bits i have sorted now, thanks to people so far who have been able to help me out. I will add more as i go along i expect.
I have a genuine gti6 catalyst, the outlet pipe has snapped. On my old gti6 the cat snapped in exactly the same place. As mine is one of the older gti6s being a ph.1, I'd imagine they'll all start doing that eventually, especially as people drive on track etc.
My solution was to weld a flexi on the end and then that had a sleeve fitment for my cat back exhaust.
Would it be of interest to you? If not I'll probably weigh it in.
62k Diablo Phase 1 Gti-6:
Project Thread
(16-11-2016, 06:49 PM)RetroPug Wrote: I have a genuine gti6 catalyst, the outlet pipe has snapped. On my old gti6 the cat snapped in exactly the same place. As mine is one of the older gti6s being a ph.1, I'd imagine they'll all start doing that eventually, especially as people drive on track etc.
Poss could be. You able to get some pics?
I think I have a standard cd player u can have next time im up or your down this way
(17-11-2016, 01:02 PM)daniel909 Wrote: I think I have a standard cd player u can have next time im up or your down this way
Ok cheers bud.
Can do at some point. It looks like a gti6 with a snapped outlet pipe. It's snapped on the pipe near the fitting to the centre section though, not on the cat.
Project Thread
Ok, has it been repaired or not?
It cracked once, got welded up, and then cracked again. I can't remember what the crack looks like but I could weld it up again. It will probably be a matter of time before it goes again though.
It depends what exhaust you are running but I put a flexi in the replacement and then had that sleeve fitment to the aftermarket cat back. Mine is one of the oldest gti6s, so I imagine this failure mode will start cropping up on others before long.
Project Thread
(19-11-2016, 10:31 PM)RetroPug Wrote: It cracked once, got welded up, and then cracked again. I can't remember what the crack looks like but I could weld it up again. It will probably be a matter of time before it goes again though.
Ok well if you can sort a couple of pics of what has been done so i can see what i would be able to sort with it that would be ideal cheers.
I've got a magnex decat pipe if you can't find a genuine Smile
(24-11-2016, 04:02 PM)ozonehostile Wrote: I've got a magnex decat pipe if you can't find a genuine Smile
Ok bud, drop me a message on facebook or something.
(07-11-2016, 07:32 AM)Frosty Wrote: Theres a few bits im after for the gti6, i will prob be adding to the list when i find out more bits i need. If you do have any parts i'm after or come across any on facebook etc let me know. If a bit of a distance away ideally parts will need to be delivered but happy to usually pick up parts if localish.
Throttle cable
Gti6 sump - sorted
Gti6 cat (ideally after a genuine 1 but i know not many of them about) - got an aftermarket 1 but ideally still on the lookout for a genuine a
Phase 3 spoiler
Standard CD stereo
Rear arch liners
Gti6 gear knob - hopefully sorted
Bonnet
Driver side wing
Side skirts
Front bumper
Hi pal,
Are you still after a driver side wing? See my thread below.
http://www.306oc.co.uk/forum/showthread.php?tid=35608
throttle cable from ecp
Throttle cable
Gti6 sump - sorted
Phase 3 spoiler
Standard CD stereo
Rear arch liners
Bonnet
Driver side wing
Side skirts
Front bumper
Hi pal,
Replied to you cheers bud, i need to update the list tbf as i have bought a few bits.
(28-02-2017, 12:36 PM)fatlapit Wrote: throttle cable from ecp
Rather try and get a decent 2nd hand one tbh. Some of the aftermarket cables are pretty poor IMO.
First post updated. If anyone any of the bits im after it would be ideal if i could collect them at a show in the summer.
I have original stereo with CD player in good working condition. £20 posted?
(02-03-2017, 10:20 PM)kentiiboii Wrote: I have original stereo with CD player in good working condition. £20 posted?
You coming pugfest or FCS?
  Gti6 parts UPDATED Matt 24 10,468 03-07-2015, 11:29 AM
Last Post: Dum-Dum
  Various GTI6 parts required. blaze_the_6 2 2,463 03-12-2014, 08:14 PM
Last Post: Jaymes306
  Wanted- GTI6 parts Kimmie 38 18,557 27-04-2012, 12:13 PM
Last Post: Jonny81191
