08-10-2016, 11:06 AM
As above, so why do GTI6's have a rear bias valve/compensator yet other 306s dont?
Rear Brake Compensators - why do GTI6 have it but not any other 306s?
08-10-2016, 11:08 AM
Anything with discs has it before EBD, not just GTi6s. All the ph3s should have the newer ABS with EBD so no need for manual compensator.
08-10-2016, 12:21 PM
As above.
Some gti's do,some dont. As with the others. In fact...drum brake beams have them too iirc Wishes for more power...
08-10-2016, 12:22 PM
Only ph3 gti6 dont
abs drum has one too
non abs drum has a pressure limiter in the rear cylinders
08-10-2016, 06:22 PM
Do I buy? rear brake pipe corroded, covered in grease or other material pipes | Charlie0 | 3 | 6,785 |
18-04-2019, 10:14 AM Last Post: Mighty306 |
Uneven brake drag on rear wheels | balkan_bozo | 2 | 2,052 |
21-10-2018, 11:10 AM Last Post: balkan_bozo |
Rear brake compensator leaking | Ben | 4 | 2,937 |
24-04-2018, 07:11 PM Last Post: Ben |
