Relocating battery - check list
Yeh Just double checking all of this before I crack on with this
1) using a leisure battery box to use in the boot, secure down.
https://www.ebay.co.uk/itm/232078691209
2) using 170A power cable from starter motor to battery.
3) keep OEM wiring from starter to loom.
4) use inline fuse - anyone suggest one?
4) earth battery in the boot
5) earth engine to chassis
Anything I'm missing or need to consider?
some way of bolting the cables together in the engine bay
maybe a M8 rubber bobbin
cable terminations
crimper for said terminations
battery terminals
nuts and bolts to fix with
some sort of sleeving to protect the cable through holes or around moving items
a way of venting the battery outside
GTI6 Info
(05-10-2016, 06:09 PM)cully Wrote: some way of bolting the cables together in the engine bay
cable terminations
battery terminals
Perfect; cheers!
What do you mean by bolting cables together ? I was planning to wire straight to starter.
(05-10-2016, 06:35 PM)ginge191 Wrote: Perfect; cheers!
you may have more than one Positive in the engine bay you need to connect too Wink
the HDI's have 3 positive cables connected at the + battery terminal for instance
GTI6 Info
There's two; but they're already connected at the original terminal for battery.
8 was going to connect this to the starter as well as the new connection.
Bump to the above post.
And using 35mm 240AMP copper cable should suffice, right? http://www.ebay.co.uk/itm/Red-or-Black-2...aKWlgm9AKg
35mm yes more than adequate
GTI6 Info
  Flat battery/ can't open at to charge battery Aaron _d95 18 15,865 01-12-2013, 08:26 PM
Last Post: C2K
