Might be running rich on start up
Hi all,
I think the '6 might be over fuelling on start up as the exhaust smells a bit when the engine is cold.
I'm not sure if this is a problem as I've not ran a petrol car for almost 20 years.
Is this normal or could this be the reason the previous cat failed?
I've had a look at the plugs and they look good and not showing the usual signs of over fuelling.
It's normal, they do run a bit rich when cold.
Ah, ok.
Thanks Tom.
  Running rich Mighty306 0 1,822 01-11-2017, 04:23 PM
Last Post: Mighty306
