battery light on!
Exclamation
Can someone help?! Own a 1.9td 306 and the battery light is coming on, when driving its off but when I switch the car off it comes on even when the key is out, battery isn't charging so need bumping or jumping every time, only started after engine came out to sort out leak on the turbo (td04) everything is back as it should be, just got this problem now! Any advice would help! Sad
  Speedo dropping off and battery light staying on HDIkyle 2 2,412 21-11-2014, 08:10 PM
Last Post: Jtrigga
