Sumps XUD7 / XUD9
Are the sumps the same on all XUD models.
I've currently got an XUD7 (Peugeot 205 - 1.8 DT) and receiving an XUD9 (Peugeot 406 - 1.9 DT) with a damaged sump.
Are these sumps the same?
I 'm quite sure they are the same dude.
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
Hmm ok, I'll give it a crack before ordering a replacement!
same as long as you dont need the aircon bit on the sump that some xud9s have
Assume you mean XUD 7 Tongue And yes, bolt pattern is the same, can be issues with oil pump pickup, but oil pump can be swapped.
(12-07-2016, 07:13 PM)darrenjlobb Wrote: Assume you mean XUD 7 Tongue And yes, bolt pattern is the same, can be issues with oil pump pickup, but oil pump can be swapped.
Ah yes, XUD7!
Spot on, thanks, shall have a play when it arrives and see what happens!
Continuing with this - both sumps removed.
XUD7 sump 'fits' apart from a locating pin on the XUD9 block (which i can file down) and the screw holes are in different locations on the two longer edges.
Rather than buying a new XUD9 sump, could I get away with drilling new holes along the longer edges with a liquid gasket ?
Just to confirm, both oil pumps are the same - removed the XUD7 pump and compared - they're like for like ThumbsUp
I have a spare sump here.
Not sure best way to post/send it?
        I Don't Have A 306.
  XUD7, XUD9 and upgrade conrods assembled 4 5,870 10-07-2017, 10:20 AM
Last Post: Ruan
  xud7-xud9 head diffrences bashbarnard 8 5,870 09-03-2016, 11:16 AM
Last Post: Danny Wideboy
  xud7 on a bosch alphabravo 2 2,681 24-02-2016, 06:59 PM
