rear beam mounts recommendations
hi all,
has this been covered in here?
looking for a good quality set for when I get the beam refurbed & fitted.
if you have supplier, part num, & apprx price that'd be ace!
Hate Housework!
febi and febi only lol
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
(24-06-2016, 09:26 PM)Stef205 Wrote: febi and febi only lol
fank you! ThumbsUp
Hate Housework!
I am also using febi beam mounts, the rear of the car felt excellent on a recent sprint day.
62k Diablo Phase 1 Gti-6:
Project Thread
where's the 'best place to shop'?
Hate Housework!
I find Misterauto the cheapest and delivers very quickly, bought loads from them recently.
(25-06-2016, 04:30 PM)MY95 Wrote: I find Misterauto the cheapest and delivers very quickly, bought loads from them recently.
thank you Smile
Hate Housework!
No idea where 'misterauto' appeared from but I've also used them and can't complain. Smile
I was the same. I had never heard of them but they were fantastic. In fact I shall also be getting more stuff from them including rear beam mounts. Their site also has good photos and descriptions of stuff which is nice.
found some reduced price febi's on fleabay so bought them. (aceparts_uk)
Hate Housework!
Another vote for Febi - fitted some last year and they were spot on.
(02-07-2016, 08:47 AM)Magenta Sunset Wrote: found some reduced price febi's on fleabay so bought them. (aceparts_uk)
That could well have been who mine were from off the bay of E. They feel very nice along with a rebuilt rear axle.
Project Thread
am having to move to 'plan-b' asap.
sand-blasted used beam (informed it was good) repainted with spray hammer, & fitted in time for end of month hols. Phew
Hate Housework!
The axle is easy enough to swap, a couple of things that will hold you up if you are not prepared:
You can either disconnect the calipers and then reconnect them, or it is possible to remove the rear beam without disconnecting the rear brake lines from the caliper, but difficult to get the beam out between the lines. If you do disconnect them, unions can be difficult to undo, lines can twist etc. so make sure you are able to deal with this if it happens.
The beam mounts through the floor require a deep 16mm socket, which is an uncommon size and not in a lot of socket sets, so check that you have one beforehand. If you need one and can't find one in a shop eh. Halfords, a 16mm spark plug socket is an option.
Project Thread
(02-07-2016, 08:45 PM)RetroPug Wrote: The axle is easy enough to swap, a couple of things that will hold you up if you are not prepared:
cheers, but i'll speak to a 'man that can' Itwasntme
Hate Housework!
I suppose making someone else do it is being fairly well prepared. lmao
Project Thread
16mm deep socket is in most sets - it's the same as the spark plug size
Edit: read all that post doh
P1 XSi track car
2.4 LWB T4
(02-07-2016, 11:33 PM)RetroPug Wrote: I suppose making someone else do it is being fairly well prepared. lmao
man that can has more tools, space, and practice than I can throw hot tea at Big Grin
Hate Housework!
ECP do Febi reasonably cheaply, especially with discounts..
most non budget brands will be fine, using o.e on my car though.
is ti work a quick flash of rattle-can b4 fitting?
Hate Housework!
(24-06-2016, 09:19 PM)Magenta Sunset Wrote: hi all,
How much are you paying for the beam to be refurbished? If you don't mind me asking?
I got some Febi ones from Aceparts_uk on Ebay
.pdf   DocScreen1.pdf (Size: 203.68 KB / Downloads: 161)
Hate Housework!
  Rear beam ...the good and the bad Mighty306 35 27,833 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,021 26-06-2020, 07:19 AM
  Rear beam rebuild MOK 21 13,607 18-03-2019, 03:40 PM
Last Post: MOK
