Moving battery to boot.
Been thinking about doing this for a while. What's the best way to go about it?
Standard battery box bolted to the floor suffice??
Many different ways people have done it. I got a leisure battery box off ebay. Does the job ok.
If you're after some wire i can sort you out with some 25mm2 stuff that i bought but wasn't really man enough to crack the xud over. Will do it for you cheap. Let me know if your interested.
Will that be good for the Rallye?
How do you go about connecting the positives together? Or is it a case of rewiring things?
Find a BMW in a scrappers and use that for it's positive and ground cables as BMW's usually always stuff the battery into the boot.
(24-06-2016, 08:54 PM)Matt Wrote: Will that be good for the Rallye?
Yeah should be fine, i got that size on the hdi and turns it over fine.
I used a junction box i got off ebay.
http://www.ebay.co.uk/itm/181364923843?_...EBIDX%3AIT
Only problem with the junction box, by positive lead is one of those crappy red screw on terminals Sad will have to change that over
(26-06-2016, 08:53 AM)Matt Wrote: Only problem with the junction box, by positive lead is one of those crappy red screw on terminals Sad will have to change that over
Cut the end off and put a ring terminal on the end, it's what you will have to do to the leads anyway so they can be connected. Need to be big terminals though, we have some big crimpers at work to do them.
Ahh okay, makes sense tbh.
Nothing stopping me but cash now haha
ive just moved mine in the 205 with a new powervamp pc680 battery used pure copper 35mm2 cable with a neat junction box.
http://www.ebay.co.uk/itm/Car-Audio-Powe...L8KqwZ7vog
http://www.ebay.co.uk/itm/PVC-COPPER-BAT...1763633142
http://www.ebay.co.uk/itm/Copper-Welding...2047024343
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
Nice one cheers. I won't be doing this for a few weeks yet by the looks of it. Too much cost and not enough work haha
  Boot light draining battery Dreijers 8 5,388 26-02-2015, 10:12 AM
Last Post: Dreijers
  Flat battery/ can't open at to charge battery Aaron _d95 18 15,830 01-12-2013, 08:26 PM
Last Post: C2K
  Battery in the boot londondan86 5 4,123 18-03-2013, 02:35 PM
Last Post: londondan86
