That darn knock...VIDEO
Exclamation
So...
Seems that whatever has been occasionally clunking in the past has not gone...and track time really made it angry.
On journey home, at 1200rpm and around 1800rpm, in any gear under light load its a horrid clunking sound. Nearside for sure. Very agricutural.
Seems to continue and appear at other random times too...but above 2250rpm and moving...lots of noise anyway from everything.
Doesnt make noise when coasting down in gear off the power
Try n get video up soon.
I'm thinking gearbox tbh...esp as it got worse during track time.
Bellhousing bolts tight?
(05-06-2016, 03:00 PM)Paul_13 Wrote: Bellhousing bolts tight?
Yeah man. They good
When you did last check the diff bearings?
Seem to have had this knock for ages, surely the gearbox is the only thing that hasn't been changed by now? Confused
(05-06-2016, 04:39 PM)Paul_13 Wrote: When you did last check the diff bearings?
Erm....
Does never count?
No whine though afaik
(05-06-2016, 04:40 PM)Toms306 Wrote: Seem to have had this knock for ages, surely the gearbox is the only thing that hasn't been changed by now? Confused
Erm. Yes. Lol.
Got one here sat in workshop... But, effort.
Your diff bearings are probably buggered
(05-06-2016, 04:57 PM)Paul_13 Wrote: Your diff bearings are probably buggered
Never known them to knock?
I have
(05-06-2016, 05:47 PM)Paul_13 Wrote: I have
Ahhh really.
Hmm. Anyway to diagnose other than swap box?
Give the drive shafts a good wobble and see if you can feel the diff moving around or listen for noise?
What box you running?
i had a knock like this few weeks later the diff was waving at me through the bell housing
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
car park full lock and slight acceleration like checking for cv joint noise, diff working then, so if bad tooth etc, will make the noise??
HDi box.
Its not cvs for sure.
Got a spare good hdi box paul?!!
Only dturbo gearbox lying around bud
I've got a spare 306 diff /bearings /cups
(05-06-2016, 08:02 PM)Paul_13 Wrote: Only dturbo gearbox lying around bud
Yeah? For a hdi?
makes sense to fit a lsd while doing the bearings doesnt it? lol
05' Evo 9 IX GT
Team eaton.
Gearbox mount nuts slightly loose?
P1 XSi track car
2.4 LWB T4
(05-06-2016, 10:04 PM)adam b Wrote: Gearbox mount nuts slightly loose?
Nah all tight
(05-06-2016, 09:58 PM)Stef205 Wrote: makes sense to fit a lsd while doing the bearings doesnt it? lol
Not commiting any more time/money to this now...
Two new projects I need to move on to.
Upsets me a bit, esp as it has been so successful this weekend/recently...
But times move on.
Did sound/feel epic yesterday though
(unless you wana donate Wink )
306 dturbo /hdi diffs are interchangeable.
I'll bring it when I return the head, which is all ready to go. Big thanks for that, diff is free by the way
(06-06-2016, 06:16 AM)Paul_13 Wrote: 306 dturbo /hdi diffs are interchangeable.
You absolute legend... Free Piggypower sticker for you! lol
I'll message you now... Much keener to swap diffs than gearboxes... For obv reasons.
Hmmmm.....
Got a video I'll try n upload...but noticed turbo sounds epic...have huge exhaust gas leak post turbo in engine bay...think my knocking js exhaust... *embarrassed* have to investigate
https://youtu.be/qBqdRdEc9Ns
Christ that's bad
Did you give the Driveshafts a wobble.?
Grab the short Driveshafts inner CV and give it a wobble.
Uh oh that really sounds like a tractor now
(07-06-2016, 06:49 AM)Paul_13 Wrote: Christ that's bad
Guna have a try tomorrow...flat out with other things...I have a major hole/crack in downpipe though..so very suspect of that
you sure nothing is caught up with a tyre? sounds bad whatever it is, does it make the noise from rest or does the noise start at a particular speed, sounds very rhythmic.
does the noise vary when weaving?
hole in down pipe, it is a diesel
watched the vid several times now, noise seems to start when clutch fully up, why are you holding it in gear?? and the car seems to jerk??? clutch problem??? as noise speed seems to increase at one point like a kid running past railings with a stick????
there also seems to be some steering wheel wobble, i would't drive the car again on the road until sorted Exclamation
No steering wobble. Drives fine.
Drove it like that on track lol
Why am I holding it in gear??....coz in neutral i slow down!??
No weave/road bump effects. No play anywhere. No wheel issues.
Yes it does jerk a little if you hold it at that rpm...could be a fuel issue unrelated
And downpipe hole..not because diesel... And its huge.
Does it pop out of gear when you take your hand off the gearstick then? Very much a diff/box issue if so. Just watched it again, that is awful. :/
No, I'm just being lazy with my hand.
No gearchange issues at all, no grinding, popping out etc
  GTi6 Knock Toms306 12 8,610 21-04-2018, 09:05 AM
Last Post: Toms306
  Rattly knock!! insomaniac45 4 3,269 22-07-2016, 01:18 PM
Last Post: Dale
  Knock Knock..... nick000 12 8,614 01-05-2014, 11:52 AM
Last Post: nick000
