XUD exhaust question
Hey folks,
Got a 1997 Dturbo. Noticed that the CAT sits VERY close to the gear change rod, and so gives a wee clunk when the car is started and stopped. The exhaust will probably need renewed in the near future, and just wondering if I can simply change it for a non CAT type, this will be cheaper and easier to fit, and will remove the clunk too... Is this OK as I believe it is a visible smoke test only, or will the MOT guy know there should be a CAT based on VIN etc?
Cat shouldnt be that close...sounds like bad fitment
Current regs say...if it had a cat...it needs one
(30-05-2016, 10:31 PM)Piggy Wrote: Cat shouldnt be that close...sounds like bad fitment
Hmmm. I did wonder why it was so close. Maybe I can drop it a bit by playing with the hangers. Looks like the CAT is welded into the pipe,no flange joins. Is this normal?
Sounds like it's been messed with
Change it for a decat and find an Mot tester that isn't an arse Smile
  gt15 exhaust elbow question scottbmxer 0 1,773 18-04-2013, 04:41 PM
Last Post: scottbmxer
