Head gasket change advice
Going to be changing the head gasket and the turbo at the weekend on the hdi
 Just need a bit of advice from some one who's done this before .
I know the head bolt torque  settings in Haynes is wrong
Is it turbo/exhaust off first and then  carry on with the HG or can you undo  all the head bolts and lift the head/turbo/inlet as one?
Obviously if taking the turbo off, subframe off
Done plenty of he's before, just would appreciate what order things need to be done in to save some time
You'll find if you're doing the turbo its easier to lift the lot...its just ruddy heavy
Is there space to lift the head off with the turbo attatched?
Pretty sure i've pulled a head off with the manis and turbo still attached before, think i had to drop it off the top mount, i'd get a mate to help you lift it though.
You don't know me well enough lol won't need any help
Thanks for the tips should speed things up, hopefully be able to do the same with the gt2052s
Can't offer any advise sorry but I'd be interested to hear if it's do-able. Good luck!
Hahah fair, i'd put my back out like that. Sad
  Head gasket and head cleaning? JTaylor2005 11 6,205 23-02-2015, 05:41 AM
Last Post: crpt
  Head Gasket thickness Mr_Nuclear 8 6,563 07-12-2014, 10:40 AM
Last Post: Uberderv
  anyone blown head gasket? rd070707 19 13,318 21-07-2012, 09:31 AM
Last Post: Ruan
