Threads: 371
29
Car Model/Spec: ford fiesta
Given 82 thank(s) in 82 post(s)
So for me on the estate its cambelt, service, axle lower, dront struts on map.
Then service lus, p bushs and detial
Just wondered what everyone else needed to do before as well
Threads: 476
81
Car Model/Spec: 306 Rallye
seam wlded sub frame
heater matrix
ds2500 pads
spare wheel
track tyres on
bolt check
5.1 fluid
fire extinguisher
clean
balance bodies
wiring
engine mounts
and much much more!
Threads: 591
54
20-05-2016, 09:46 PM
(This post was last modified: 20-05-2016, 09:47 PM by Piggy.)
206...service next week as its due in 400miles.
306...finish off cooling aids....
"airbox"
Service engine
Servive brakes
Bolt n general check
Fit undertray
Meth injection
Wash and first wax of the year.
Maybe tidy up inside a bit
Threads: 24
0
Car Model/Spec: Gti6 HB soooper charged
Given 10 thank(s) in 10 post(s)
Passenger side track rod end, airbag replaced with glovebox and a damn good clean
Threads: 186
38
Car Model/Spec: MG ZR VVC
Given 21 thank(s) in 19 post(s)
Fit oil cooler so can stay out longer on track / reduce risk of fking the engine
Fit thermal intake gasket without a vacuum leak
Sort out front tyre as it's taken some abuse
Gearbox oil
Fix abs sensor issue
Threads: 465
114
Car Model/Spec: Vauxhall
Given 98 thank(s) in 92 post(s)
Things left to do before fcs...
oil change
fit track disc/pads
balance some wheels
clean the girl
general nut n bolt check
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 41 thank(s) in 38 post(s)
Front left and right trackrods, do want to sort the front bumper as the skin has come away on the passanger side.
/Toseland
Threads: 45
3
Car Model/Spec: phase 2, stage 2, gti 6.
Given 6 thank(s) in 6 post(s)
Blend in the paint on the rear arches after I did such a shit job of rolling them on the track side.
clean inside and out.
track front wheels
nuts and bolts check
Threads: 465
114
(21-05-2016, 08:02 AM)cully Wrote: Things left to do before fcs...
oil change
fit track disc/pads
balance some wheels
clean the girl
Threads: 541
124
Swap tyres front to rear, fill with fuel*, check new tent came with pegs, find BBQ
*I'm probably going to have to fill with fuel at least 4 times before FCS if not 5 or 6 times. Smiles per gallon FTW.
Threads: 164
25
Given 4 thank(s) in 4 post(s)
Sort constant heat problem
Idle / revving problem
Adjust suspension to be stiffer
Fix knock on front left
Fix ABS system
Change wheels / tyres
Full detail
And more depending what parts I can get hold of lol
Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Given 30 thank(s) in 30 post(s)
Not a huge amount tbh.
Try and find/fix boost leak (well it sounds like it has one)
Maybe fit powerflex bushes on suspension arms
Give it a decent clean
Threads: 371
29
(20-05-2016, 09:41 PM)bashbarnard Wrote: So for me on the estate its cambelt, service, axle lower, dront struts on map.
so mines done apart from map and clean now done it all yesterday
Threads: 58
3
Car Model/Spec: Loads
Given 9 thank(s) in 9 post(s)
nothing at all, Going to Bournemouth wheels which for me is much better
Threads: 448
51
Finish the strut brace and fit
Align exhaust
Clean a lot
Done
Threads: 136
11
Car Model/Spec: 306 hdi stage 2 & 205 DTI
Given 39 thank(s) in 39 post(s)
(22-05-2016, 01:09 PM)Frosty Wrote: Maybe fit powerflex bushes on suspension arms
Remember to do your tracking after, because they change the geometry slightly
Threads: 374
38
Car Model/Spec: GTI 6
Clean and give a full detailing... that's all
Threads: 128
21
(23-05-2016, 07:07 AM)ginge191 Wrote: Buy less of a hairdresser's car... that's all
EFA
/Toseland
Threads: 374
38
23-05-2016, 07:24 AM
(This post was last modified: 23-05-2016, 07:24 AM by ginge191.)
(23-05-2016, 12:30 AM)Matt Wrote: Finish the strut brace and fit
Align exhaust
Clean a lot
Done
We having a cleaning day?! Doing mine on the Thursday, you about?
(23-05-2016, 07:22 AM)toseland Wrote: (23-05-2016, 07:07 AM)ginge191 Wrote: Buy less of a hairdresser's car... that's all
EFA
The megane is no 'cc' model!
Threads: 110
20
(23-05-2016, 06:53 AM)Paul_13 Wrote: (22-05-2016, 01:09 PM)Frosty Wrote: Maybe fit powerflex bushes on suspension arms
Will do cheers
Threads: 20
0
Car Model/Spec: gti 5 Turbo
Given 2 thank(s) in 2 post(s)
change ex cam seal
put fuel in see how long gearbox lasts for
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 32 thank(s) in 32 post(s)
Loads I want to do, but realistically >
Get exhasut downpipe sorted with a flexi.
Get a good wash and polish on the go.
Hope it doesn't blow up.
Would love to get some tuning in too, in proper need of setting up since the rebuild.
Threads: 448
51
(23-05-2016, 07:24 AM)ginge191 Wrote: (23-05-2016, 12:30 AM)Matt Wrote: Finish the strut brace and fit
Align exhaust
Clean a lot
Done
EFA
I'm game, I've got the whole weekend of so will see what I am working Thursday
Threads: 591
54
(20-05-2016, 09:46 PM)Piggy Wrote: 206...service next week as its due in 400miles.
"airbox"
Service engine
Service brakes
Fit undertray
Meth injection
Polish up wheel bolts
Finish off oil cooler
Rear camera mount
Fit battery fuses
Internal central camera mount
I like adding to lists and immediately crossing things out... Feeling of accomplishment
Threads: 541
124
My list now has added to it:
Get wheel bearing changed
Fit new pads and discs at the front
Add more cable ties
Top up coolant
Top up pas fluid
Threads: 164
25
I now need to change the throttle cable too
Threads: 24
0
(25-05-2016, 07:46 AM)rocker8742 Wrote: I now need to change the throttle cable too
I will prob change mine too because my throttle cable is soooooo long it looks naff. Slightly shorter of the xsi 16v so will get one of those me thinks
Threads: 164
25
(25-05-2016, 11:49 AM)Xsikid Wrote: (25-05-2016, 07:46 AM)rocker8742 Wrote: I now need to change the throttle cable too
Mine just snapped this morning lol
Threads: 541
124
(24-05-2016, 10:01 PM)Dum-Dum Wrote: My list now has added to it:
Add more cable ties
Top up coolant
Top up pas fluid
And now add to that new calipers both sides as it turns out that at least half the pistons on the nearside are seized, one can't be budged and I've been told if the nearside is like that then the drivers is probably not far behind so might as well replace both.
Anything else goes wrong and I'm gonna have to sell my track time.
Threads: 591
54
How about just reduce your alcohol budget so you'll be sober enough to use the tracktime?
