Air bag removal
Air bag removal
help needed! Want to remove the air bag in the dash my my ph2 gti6. Iv got the glove box and I know it's a straight swap but what do I need to do about the air bag light? Cheers
Cully on here does the resistor kits to turn the light off
Can't you just turn the airbag off with the key down by the headlight adjuster?
(27-04-2016, 02:10 PM)Mattcheese31 Wrote: Can't you just turn the airbag off with the key down by the headlight adjuster?
No mate can on my xsi but I guess that's because it's a phase 3?
(27-04-2016, 02:04 PM)Pug0BZ3011 Wrote: Cully on here does the resistor kits to turn the light off
Ok pal cheers
yes but it brings up another light saying it is disabled Wink
I do sell fused resistors
if you are interested PM me
GTI6 Info
yeh you need fused resistors. And... you can fit a top glove box but you will be missing the metal frame so it will be slightly insecure and a few screws wont grip.
(27-04-2016, 03:44 PM)Eeyore Wrote: yeh you need fused resistors. And... you can fit a top glove box but you will be missing the metal frame so it will be slightly insecure and a few screws wont grip.
there is no metal frame that I recall, you just use those little metal clips that slot on the holes then the screws go through them, don't know what they're called Smile
Hi mate I can open your pm but it won't let me reply for some reason my account is verified so tech glitch I presume
add me on FB addy is in my profile here Wink
am at work ATM maybe slow replying
GTI6 Info
