Threads: 136
11
Car Model/Spec: 306 hdi stage 2 & 205 DTI
Given 39 thank(s) in 39 post(s)
Sure my HG has gone as it's losing water and pressurising the coolant system.
There's of plenty 8v hdi's at the local scrap yard just need to know if they're all compatible
Threads: 591
54
Whats wrong with your hdi head?
HG fail doesn't mean head fail.
Afaik, they are all the same...no doubt there must be a difference somewhere that a peugeot boffin knows
Threads: 91
2
Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
Given 5 thank(s) in 5 post(s)
Fully built head on Servicebox says 0200GN. Doing a search on that part number brings just about the whole Pug family....206/306/307/406/607 plus the vans. For Shitroen, Xsara 1 & 2/Berlingo/C5/C4/Xantia/Picasso plus vans.
Probably best to try and stick to the same age group though...
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 136
11
Sweet Cheers
I need a spare head to get skimmed and minimal down time as the wife needs the car as well
Threads: 386
87
Given 117 thank(s) in 116 post(s)
Have you got a sniff tester to check it? HGs rarely fail on HDi's but I know what your luck is like lol.
Threads: 136
11
Was driven gently yesterday by wife, went down this morning to change rad cap and top up water as she said the light come on.
Opened the cap up and there was quite a bit of pressure in the header tank. I bled the system and there was no air strangely
Threads: 386
87
14-04-2016, 11:02 AM
(This post was last modified: 14-04-2016, 11:03 AM by Toms306.)
Might just be a faulty cap then?
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 40 thank(s) in 37 post(s)
get that sniff test done mate..
/Toseland
Threads: 50
0
Car Model/Spec: 306 HDI Dturbo
Given 0 thank(s) in 0 post(s)
I've got the same issue with my Dad's HDI - pressurising coolant, spewing it out the header tank (especially if driven hard). Tried swapping the rad cap, bled the system etc (no air), coolant all circulating fine. I've read a lot of posts on numerous forums about pressurising coolant with the 2.0 HDI and they all seem to lead to a head gasket replacement and a sniff test doesn't always pick it up. My sister's old HDI had the same problem and the one after that was starting to go before it was traded in. So I'd say it is definitely getting more common!
Can't decide whether to drop another engine in or just to replace the head gasket. I too am thinking about getting a used head to skim in advance for speed.
Threads: 136
11
Just un done the cap again and hardly any pressure come out, the wife had been driving it so obviously not hard.
Seems to be only at high psi. Wonder if I'll get away with a nip of the head bolts? Worth a try.
Next question, are the back bank of bolts in the rocker cover? It's raining outside or I'd go look
Threads: 50
0
If you go ahead are you going to take the head off in situ or remove engine for easier access?
Threads: 136
11
In situ....
Going to be interesting. Fitting gt20 at same time
Threads: 18
0
Car Model/Spec: Fabia 1.9tdi 105 PD
18-04-2016, 09:03 AM
(This post was last modified: 18-04-2016, 09:04 AM by maxaret.)
Hope it goes well for you - I had a subtle head gasket leak some years ago (not Hdi) and two sniff checks at different garages failed to confirm it,I didnt have time to fix myself so got a garage near where I worked to change it for me,the only evidence of a leak was a small slight 'polished' section on the HG,but it cured the cooling system pressurisation etc.
Because they were late finishing the job I didnt get the car back until the day before the car insurance ran out,so I had to drive it 70 miles to home that night,it was sort of going ok but a little down on power (xud non turbo) but the engine was sounding really weird,the car was already up for sale so I spent that saturday having to refit the cam belt - the chimps at the garage had fitted it one tooth out LOL.
Threads: 50
0
Good luck! Be interested to hear how you get on.
