Cam sensing with vernier pulleys
This gti6 engine I have, has 285 cams in it. But it runs standard pulleys and management atm. But it doesn't run right atm. And I need to investigate this issue.
Long story short. I plan to put some vernier pulleys on but pipers are listed as not having a pickup for cam sensor. So wandered what other people had ran in the same situation. xx
They'll be on aftermarket management I'd highly suspect.
The stock pulleys *are* vernier anyway.
quite unlikely it has 285's unless it has different pistons, even the hydraulic profile 285h's are marginally borderline on stock unskimmed head.
It's got 285s. And about 2k worth of other bits invoiced too. And I have the old boxes with the standard cams in. Welsh pug I'll pm you the invoices tonight to see. I've spoken to you before actually on rr. I have a 309 3dr good wood. ?
  Locking cam pulleys DeeTurbo 10 6,311 02-07-2016, 02:43 PM
Last Post: DeeTurbo
  Adjustable cam pulleys Lolben91 3 2,759 08-06-2015, 09:46 AM
Last Post: maxzy
  Cam pulleys Grant 16 8,637 03-05-2012, 09:28 PM
Last Post: Ruan
