diesel pump leak
noticed this morning very strong smell of diesel so started my car and popped my bonnet to see diesel dripping on to my alterantor from what looks like a plastic or rubber circle bung on the side of the pump is this a seal or change pump ?
sounds like the cap on the front of a Lucas pump, there is a seal there yes.
If it's the plastic round plug with a one way screw, that's the cap to open up the internals of the pump - sounds like it may have been tuned.
You could try and tighten it, but if not any scrapyard will likely have a car with same engine can you can nick the cap off it, just need a screwdriver and a hammer to undo it.
thanks for replies managed to tighten up abit with a large flat screwdriver bit but judgeing by the cap its chewed round the edge and lost its seal ive stopped it from puring out to a drip every now and then so will get a new seal
  Major fuel pump problems, air leak, head gasket? Dantheman1312 2 4,308 22-08-2016, 09:57 AM
Last Post: r3k1355
  name of the plug on diesel pump callumh121 5 3,619 18-04-2016, 05:44 PM
Last Post: Danny Wideboy
  Presumed Lucas Pump Leak ozpug 4 3,656 10-09-2015, 12:28 PM
Last Post: pioneer DJ paddy
