Mileage and speed rev dials FIXED
Rainbow
Hello I noticed on my 306 hdi sometimes when starting the car near the mileage clock it will show like a alarm clock or timer thing. The rev and speed counter both move up from 0 to the same place near max higher up then go back down to normal?
Just seeing what this means?
Thanks
poor battery voltage to the clocks Wink
could be a few things from
bad earths
bad connections
poor battery
GTI6 Info
mine does that too sometimes. I take the view the battery is a bit low.
got myself a dash solar panel to compensate a little.
Hate Housework!
I've checked the battery while engine running and off the battery 13v+ when off when on 15v+ so the battery good.
I've cleaned the connections on the battery, 2 earth's below the battery also earth near driver front headlamp.
There anymore earths or connections to try and clean.
+ connection on the alternator
when my clocks did the dance the wire was burned off the alternator
GTI6 Info
(06-03-2016, 11:06 AM)cully Wrote: + connection on the alternator
nice one! Confused
Hate Housework!
Ive sprayed wd40 everywhere the problem cleared up now thanks.
shouldn't have 15+ on the battery!!! you need a new rectifier on the back of the alternator
  Fixed please delete Leemus 11 6,741 18-05-2017, 08:01 PM
Last Post: Leemus
