Wideband lambda with Innovate LC-1 controller
Bought this a little while ago when I was building the new engine. It's a wideband lambda connected to an Innovate LC-1 controller. The controller can output both wide and narrow band, to a gauge and ECU for example, and log the values it sees. I bought the programming cable for it separately so you can plug in to it. Also comes with an LED push button switch to allow you to recalibrate it. I'll supply the other side of the connectors it uses so the buyer can wire it up as they wish.
£40 + postage
[Image: IFVg7VRl.jpg]
[Image: KRRC3RLl.jpg]
  306 GTI6/Rallye Genuine Cat with Bosch Lambda Sensor £60 roland rat 2 1,712 16-06-2016, 04:41 PM
Last Post: RetroPug
  Innovate LC-1 wideband + Bosch wideband sensor Niall 0 661 01-06-2014, 07:02 PM
Last Post: Niall
  FOR SALE: Innovate LC-1 wideband controller + sensor Rippthrough 7 1,607 14-05-2014, 09:58 AM
Last Post: Niall
