For Sale: Innovate LC-1 wideband controller + sensor
Innovate LC-1 wideband lambda controller and Bosch sensor - £70
Few years old but in good condition, I wrapped all the excess wiring loom up when I installed this, and didn't cut it down, so has plenty of wiring length for almost any installation.
Already has the white 2-pin Junior timer plug fitted to the loom so you can plug it straight in as a replacement sensor for most Peugeot applications.
Also has an extended wire for the reset button + LED warning lamp - I combined them into a light-up button (comes with it) so you can monitor/reset it in the car. I had it built into the dashboard along with the output to connect to the laptop.
Also comes with a copper sheet heatsink for the sensor for turbo applications or use close to the cylinder head, and includes the 3.5mm jack to RS232 lead for reprogramming/monitoring through a laptop.
Off the car, boxed up and waiting for a new home Smile
£60 posted and I'll pay now?
£70 and I'll post it you for free Wink
any idea on the total range? ie suitable for derv application?
7.35 to 22.5 total range for the A/FR, there is a diesel setting in the firmware (along with LPG and Meth, iirc) and the sensor is compatible , obviously it'd probably just show full lean when idling.
For those that requested some pictures:
[Image: Wideband1.jpg]
[Image: Wideband2.jpg]
Smile
There's the comm lead and heatsink not in the pics but they will come with it.
Provisionally sold.
(14-05-2014, 09:38 AM)Rippthrough Wrote: Provisionally sold.
Damn right it is Big Grin
  Wideband lambda with Innovate LC-1 controller DemonDriverDan 0 1,411 05-03-2016, 10:24 PM
Last Post: DemonDriverDan
  Innovate LC-1 wideband + Bosch wideband sensor Niall 0 1,429 01-06-2014, 07:02 PM
Last Post: Niall
