Any difference in blower motor
Thumbs Down
Is it just a case of air con and non air con?
Need a new blower for the Rallye as it isn't the heater resister it's the motor that's completly gone.
Unless there is something else to check before replacing?
Checked the plugs on it? Mine died. + cable had fallen off it Tongue
Pretty sure they are different as i think the resister is part of the AC heater motor. You checked you got a live down at the plug that goes to the blower motor?
Definitely different between AC and non-AC. Not sure if ph1 is different from ph2/3 though.
Ph1 2 and 3 are all the same ac\non ac dependant. I've swapped enough of them around lol
It had power etc. It was really intermittent with working, some days it would work. It would randomly cut out.
What plugs should I check/what pins on the plug?
Sounds like problem I had with mine. I just removed rubber cover on blower motor itself, and reconnected contacts. Motor still is noisy on speed 2, but it works all the time.
I decided that motor is working ok, when connected directly to battery it blow full speed, so I ruled out motor itself, also checked all fuses and all were good, so only thing left was contact points.
  306 Blower motor replaced and working but no air coming from vents? Zubes3 4 4,760 19-09-2020, 04:58 PM
Last Post: Zubes3
  Update: blower motor issue full fan speed all the time rich_n_stace2014 5 4,146 01-05-2016, 08:24 PM
Last Post: rich_n_stace2014
  Another blower motor problem! NOSE 0 2,281 25-03-2016, 09:42 AM
Last Post: NOSE
