Update: blower motor issue full fan speed all the time
I had been speaking to Tom on here recently with regard to a blower motor that won't adjust when dial is turned and this is just a quick update
Disconnected temperature sensor behind map light still blows full
Checked voltages on the wire from control panel to motor and the voltages for each selection on dial are switching fine
Cut the wire and it still blows in full rather than shut off which I wasn't expecting
This is the third blower motor and they all test fine on the donor car
Any more ideas guys?
Jammed on relay?
Not sure mate, worth a look thanks
The symptoms point to a faulty blower resistor but can't be unless somehow the car is killing the resistors?
Been looking for info on how the phase 3 blower works, diagrams etc but everything I see is from the non air conditioning model.
All I have found with regard phase 3 is that Apparently the fan is supposed to be on low all the time to cool the transistors but dont understand where it would get the signal for that.
The blower as far as I can see has positive, negative and control wire but I cut the control wire so shouldn't be getting a switch voltage
Relay checks out fine, swapped it with another green one (power windows?)
I've tested the control wire and voltages are incrementing fine.
Do you know the part number for blower transistors? Some say it's MJ11015 and other forums MJ11016
Don't want to fit the wrong ones as I believe one is NPN while the other is PNP!
If anyone can confirm that would be great
I'm still stuck on this if anything me is able to help pls!
  306 Blower motor replaced and working but no air coming from vents? Zubes3 4 4,472 19-09-2020, 04:58 PM
Last Post: Zubes3
  Another blower motor problem! NOSE 0 2,177 25-03-2016, 09:42 AM
Last Post: NOSE
Thumbs Down Any difference in blower motor Matt 6 4,041 09-02-2016, 08:59 PM
Last Post: Dreijers
