Threads: 9
1
Car Model/Spec: HDi Meridian
Country:
I ended up buying a whole fuel pump for the two bolts haha. I'll get it measure up tomorrow for you!
Threads: 9
1
Country:
M6 * 15mm is correct. Has a T30 Torx head.
Threads: 9
1
Country:
No idea how to measure pitch, I think it's standard? I've included a photo if that helps.
Image(s)
Threads: 41
28
Given 85 thank(s) in 84 post(s)
Probably 1.0mm pitch, use the links below to find them
Threads: 9
1
Country:
27-05-2016, 09:19 PM
(This post was last modified: 27-05-2016, 09:19 PM by BiG K .)
The O-rings are cheap enough to buy....if your dealer will get them in. Some O rings are supplied in packs of 5, some in 4 and some in 3... they were being a bit arsey with me when I went to go buy the O rings.
Threads: 135
5
cool, thanks, fore armed etc., looks as if a 10mm hex head will fit??
Threads: 117
119
Given 105 thank(s) in 105 post(s)
You might find you have clearance issues getting a socket over it, being so close to the solenoid body as they are.
Threads: 70
10
Car Model/Spec: HDi Estate
Given 9 thank(s) in 9 post(s)
Yeah, hex head is a no go. Bolt won't even fit let alone the socket.
In a pinch you could use a 30mm long bolt and a 15mm spacer, but not recommended.
Threads: 135
5
thanks, will go down the allan bolt route
