Timing belt jumped.
Hi all. Had my aux belt snap on me.....again!! And a bit of it had tangled up in the timing belt. It juMped a few teeth on the pump and the cam and was running like a bag of old spanners. I've re timed the belt but now it won't start from the key at all unless the engines warmed right up and had a horrible tapping noise. Is this bent valves? If so how hard are they to swap over? Thanks
That would sound like bent valves to me a head swap is easy although it maybe worth putting a whole engine in these are really easy to pull out couple hours max for some one that's never done one then same to stick new one in.
I do have a good engine for sale removed running and on 115k comes ready to drop in
How much you after for it?
£110 collected from Derbyshire for extra if you can get the car to me I can do a fitting service if required
  XUD timing belt kit compatibility weka 4 4,918 21-08-2017, 08:17 PM
Last Post: weka
  DW8 Timing belt cover / water pump bolt size? jamesgmg 13 11,008 06-07-2017, 03:41 PM
Last Post: Mighty306
  How do you do your timing belt? ginge191 9 11,428 12-09-2016, 03:14 PM
Last Post: ginge191
