Threads: 171
46
Car Model/Spec: Black 3dr Dturbo
Given 1 thank(s) in 1 post(s)
I take it theyre all the same
Ed says the ones on my car are from an hdi
There's a ph1 xsi is a local breakers that should have 266 disks/pads?
Anything else in the pug range that will have the same? 406hdi?
Thanks in advance :-)
Threads: 91
83
They did a Bosch and a Lucas caliper/carrier - two different sets of pads, discs are the same however.
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
Threads: 119
15
Car Model/Spec: Ph1 Diablo DT
as long as the piston aint damaged youl be fine use a big g clamp to push it back in unless you want to dislocate your thumbs! thought about upgrading you can get a 283 setup of a 307 for around £40
www.prestige-auto-care.co.uk
Threads: 171
46
Just want something direct fit
They are 17mm the 2 bolts for calipers?
Or 19?
Threads: 91
83
Thing is that the 283s aren't much better, the caliper is the same, it's only the carrier that's different and they're so much heavier...
Until you've upgraded the pads, no point in going for 283s... Unless you're stonking it round a track and repeatedly abusing the brakes, the 266s on decent pads are perfect.
You can make 266s better than 283s with better pads... The pads are everything with these.
Threads: 171
46
Abs caliper on a non and car? Get away with cutting the abs wires?
Threads: 91
83
They're Bosch calipers FYI...
They aren't the same as the ones you have, I'm 99% yours are Lucas calipers...
The calipers will be fine with a clean though.
Threads: 171
46
Yeah they're Bosch and I think k mine are Lucas but I'll be getting the whole caliper so no problem?
Will my brake lines fit these?
Threads: 91
83
Why do you need a new caliper?
Why can't you just put new pads and discs on?
Much easier!!!
