27-11-2015, 12:31 PM
So my brake pedal is solid and braking is very sketchy feels like I don't have any brake servo helping the braking. Anyone had a similar experience?
Urgent brake help
27-11-2015, 12:36 PM
is there any vacuum ?
pipes split collapsed ant the bends or joints? yes i have had this it was a collapsed vac pipe between vac pump and bulkhead https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
27-11-2015, 12:39 PM
(This post was last modified: 27-11-2015, 12:49 PM by Nathan1305.)
27-11-2015, 12:52 PM
is there vacuum anywhere?
disconnect the pipes to check https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
27-11-2015, 01:09 PM
Try taking the pipe off the vac pump and see if its got any suck there
27-11-2015, 01:15 PM
Have you/anyone else been in the engine bay recently? Probably disturbed something if it's gone like that suddenly.
27-11-2015, 01:17 PM
Blank EGR pipe with a screw that's fallen out?
27-11-2015, 01:29 PM
There's no vaccume between the pipe on the bulk head and the servo
27-11-2015, 01:31 PM
Is there any at the vacuum pump then?
27-11-2015, 01:37 PM
the black n white plastic 3 way joint lost its rubber tit? or broken off
None coming from here
27-11-2015, 01:39 PM
spay some wd40/plusgas in their the valve may be stuck if not the pump is fubared
27-11-2015, 03:09 PM
You'll need to get used to man braking till you get it repaired but if it is just a lac of vac the system will be fine bar being very heavy.
