Urgent brake help - Printable Version
+--- Thread: Urgent brake help (/showthread.php?tid=32629)
Urgent brake help - Nathan1305 - 27-11-2015
So my brake pedal is solid and braking is very sketchy feels like I don't have any brake servo helping the braking. Anyone had a similar experience?
RE: Urgent brake help - cully - 27-11-2015
is there any vacuum ?
pipes split collapsed ant the bends or joints?
yes i have had this it was a collapsed vac pipe between vac pump and bulkhead
RE: Urgent brake help - Nathan1305 - 27-11-2015
(27-11-2015, 12:36 PM)cully Wrote: is there any vacuum ?
I'll take a look now weird how it just randomly happen
Can't find any leak or damage to any pipes
is there vacuum anywhere?
disconnect the pipes to check
RE: Urgent brake help - Frosty - 27-11-2015
Try taking the pipe off the vac pump and see if its got any suck there
RE: Urgent brake help - Poodle - 27-11-2015
Have you/anyone else been in the engine bay recently? Probably disturbed something if it's gone like that suddenly.
RE: Urgent brake help - Toms306 - 27-11-2015
Blank EGR pipe with a screw that's fallen out?
There's no vaccume between the pipe on the bulk head and the servo
Is there any at the vacuum pump then?
the black n white plastic 3 way joint lost its rubber tit? or broken off
None coming from here
spay some wd40/plusgas in their the valve may be stuck if not the pump is fubared
RE: Urgent brake help - Dum-Dum - 27-11-2015
You'll need to get used to man braking till you get it repaired but if it is just a lac of vac the system will be fine bar being very heavy.
