...knew it would happen soon
For the past week the 306 hasn't been starting first time and often starts the second. However today it failed completely, it's turning over but just doesn't fire up, and now the battery is run flat with trying....CHRIST
Fuel pump relay would be my first port of call.
Unplug it and plug it in a few times incase there's corrosion on the pins
Sorry to be a bif but do you know where that is?
Its the brown relay I mentioned in your other thread. Smile Located behind the ECU.
Spot on, cheers, I'll go do that now, pointless in the dark and when the battery is flat but I'm desperate as I have work tomorrow haha
Good luck...it's a bit of a pain to access in the light!
How the heck do you unplug/get to that?
It has a metal clip round the body iirc which u can prise off with a flat driver! Put it back when your done!
The metal type paper clip looking thing? I've took that out and kept it safe. But then it's difficult to actually take the connector off, I can see something red but apart from that I'm clueless
The red thing has to be pulled out before the plug can be separated, I 'think' it pulls towards to the suspension strut, you'll need a flat blade or strong finger to move it though, doesn't slide easily.
Sounds like a nightmare already lol, I'll keep the thread updated to say how it's going
