Hdi 90 Bosch R65 pump and injectors, bosch ecu and barrel key, clocks etc 85k
Have a few parts lying about someone might be able to use-
Bosch R65 pump, without regulator good working order when removed £15 +£6 postage. (regulator gone)
Set of 4 injectors £25 +£6 postage. All came out nice n easy!( GONE )
Set of clocks showing 85K £15+£5 postage.
Bosch ECU and barrel and key £25 +£5 postage.
All parts removed from a 2000 W Hdi 306 5 door
4X window regulators - 2 front 2 rear £20 +£5 postage
Heater control panel, ac button has plastic coating missing on centre, £5+£5 postage
All parts worked well when removed
where the injectors rattly at all? and did you have low rpm juddering with them?
(08-10-2015, 06:55 PM)bashbarnard Wrote: where the injectors rattly at all? and did you have low rpm juddering with them?
PM'ed + Don't remember any low rpm judder!
What numbers are on the injectors mate?
(08-10-2015, 07:33 PM)Paul_13 Wrote: What numbers are on the injectors mate?
Hi Paul, will send a PM with numbers later as I'm out for the next couple of hours!
just to let you know you also need the bsi to make that ecu key combo work. its under the dash. takes about 5 mins to get to if you still have the car. also money sent for injectors now.
(09-10-2015, 06:15 PM)bashbarnard Wrote: just to let you know you also need the bsi to make that ecu key combo work. its under the dash. takes about 5 mins to get to if you still have the car. also money sent for injectors now.
Booooo it's gone! So ecu and barrel useless without BSI?
Yep Sad
  FOR SALE: XUD with bosch and gearbox from 306 - £80 collect Warrington nominous 2 3,100 03-11-2020, 12:36 PM
Last Post: ekjdm14
  FOR SALE: 2 x Bosch VE pumps ginge191 2 3,661 16-09-2017, 08:03 PM
Last Post: ginge191
  Xud bundle deal bosch pump fmic xudlingo 0 2,116 11-01-2017, 06:13 PM
Last Post: xudlingo
