rear brake flexi hoses
rear brake  flexi hoses.  1999/2000 hdi estate
bendix rear disc brakes, hoses have pipe "bolts" unions rather than bolt one end and nut the other.
both hoses on the car seem the same length and the system does not have an axle load brake limiting valve, just plain pipes from the flexi to the front of the car.
which hoses are the correct ones for this car please ?
europarts pagit 135545048? LEFT
same for left and right??
servicebox says:
4806 65 BRAKE HOSE REAR AR LONG 194
afaik they will be on the same length left and right, look under the car.
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 13,056 18-04-2019, 10:14 AM
Last Post: Mighty306
  Uneven brake drag on rear wheels balkan_bozo 2 3,963 21-10-2018, 11:10 AM
Last Post: balkan_bozo
  Rear brake compensator leaking Ben 4 5,912 24-04-2018, 07:11 PM
Last Post: Ben
