Handbrake weak effort
Hi guys car failed mot on passenger handbrake being weak. When jacked up you could literally turn it with your hands.
Its an Hdi with rear discs so I adjusted the tension on both cables which improved it a bit but still a massive imbalance.
When the rear is jacked up and no brakes applied the drivers wheel spins freely but the passager one only spins 1 turn then stops.
Am I looking at a handbrake cable issue or something to do with caliper?
[Image: 20gh7o0.jpg]
Probably both, how was the service brake effort?
service brake was fine although I dont have the figure to hand he said it was fine.
Was thinking maybe a slight bind on that side or stretched cable?
cables seized / caliper handbrake cable leaver siezed / needs adjusting properly / disc pads low
GTI6 Info
  Weak rear brakes DragonRacer 7 4,146 17-07-2013, 08:40 AM
Last Post: DragonRacer
  HELP NEEDED: Very little braking effort on the front puglove 31 12,368 14-05-2012, 08:10 PM
Last Post: swampy
