Glow plugs on constantly
So basically lus suddenly wouldnt start the other day. well not very well would eventuality go. so pulled the glow plugs out to replace and not one was working. thought while im here i may as well do the glow plug light mod as i have done in the past that keeps the light on even when it usually goes out.
So it clicks the glow plugs off when your pre heating then starts them up again while running and leaves them on. i know they usually stay on a bit but indefinitely i know they should not. any ideas??
So after fiddling about with relays. The one under the bonnet. Brown one. If I remove it the glow plugs work exactly as they should.
So finally figured out what happened. A 20 amp fuse had gone. Which seemed to control the brown relay under the bonnet that in turn was triggering the glow plug relay while running. No I don't have a wiring diagram to hand to see how they are all connected. All I know is that I can let Lu drive it again without burning out a set of new glow plugs.
Went to the car this morning. Still doing it. Super annoying.
So the story thickens. After being mega pissed off this morning. The light went out after 5 mins. But later it was only on for about a few seconds after running. Thinking I may have a dodgey temp sensor. I have a spare somewhere I think.
unplug the temp sender, see what happens
though the light should still go off even if post heat is working, so I'd change the big relay.
(10-07-2015, 11:49 AM)welshpug Wrote: unplug the temp sender, see what happens
I now have a big relay spare off one of my old motors and a sensor. I'll try big relay first though as cba to let coolant out.
you wont lose much if any.
I'll have to make it quick as the spare sensor is in my motor not in use anymore.
  3 sets of glow plugs in 3 months???? HELP wdoyle2410 4 5,236 31-08-2018, 01:07 AM
Last Post: wdoyle2410
  Glow plugs unscrew but can't be removed EdAppleton 15 9,081 07-11-2016, 04:17 PM
Last Post: EdAppleton
  Glow Plugs or what?! timpug 7 5,961 23-11-2015, 08:00 AM
Last Post: timpug
